Dash lights
Old 08-14-2015, 02:30 AM
1st 4 eyed fox
1st 4 eyed fox's Avatar
Default Dash lights
I just picked up an 85 4 eyed foxbody and my dash lights don't work I have ordered a new switch it should be here in a couple days but just curious of where else to look if that does not solve the problem. I have power across the fuse. If that don't work then I guess I will see if I have power to the light socket it self I just didn't want to tear all that out. Thanks in advance
1st 4 eyed fox is offline
Old 08-14-2015, 03:51 PM
silver91gt
silver91gt's Avatar
if the headlights turn on, its not the switch that is busted. The dash lights run through the dimmer switch, then to the dash lights. I would suspect the dimmer is at fault if there is power on the fuse. the dash is real easy to remove and takes about 15-20 mins to do.
silver91gt is offline
Old 08-15-2015, 02:15 AM
1st 4 eyed fox
Default Dash lights
The dimmer and headlights are all in one package it has the know you pull out and twist for the dash and dome lights
Old 08-15-2015, 02:16 AM
1st 4 eyed fox
Default Dash lights
*** not know sorry autocorrect
jwog666
12-27-2021 08:09 PM
folivier
10-02-2015 05:34 AM
jc409
Convertible Tech
09-26-2015 08:28 AM
09-25-2015 09:06 AM
accarter
09-21-2015 11:56 PM
Quick Reply: Dash lights
