NO Reverse or 5th
NO Reverse or 5th
So i just replaced the clutch in my 1993 mustang and the car drove fine had all gears but when i got home my car was leaking trans fluid used mercon/dexron
checked the leak and took out the fill plug to see how much fluid i lost after replacing the fill plug i lost reverse and 5th gear and have no idea what happened
Figured it out
I figured out the problem thank you all for replying I removed the reverse plug and the arm disconnected I have pulled the trans spit it and put the pin back in place getting ready to replace the trans
