ignition switch
Old Dec 23, 2015 | 06:28 PM
jc1's Avatar
jc1
Default ignition switch
how can you test an ignition switch to see if its bad? when I insert key the chime works when door is open could I assume its good?
Old Dec 23, 2015 | 08:31 PM
bluebeastsrt's Avatar
bluebeastsrt
No don't assume it good. The tumbler inside the ignition could be bad. You have to check it with a multimeter when the key is in the on position. The tumblers fail often on old cars.
Old Dec 25, 2015 | 08:25 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
his problem is it won't crank......the tumbler works fine, at least when he called me that was what he said, unless things have changed since then. Jim, if you think it could be the clutch switch, did you unplug it and stick a jumper wire in it to bypass the switch?....remember have car in nuetral if you do that.
Old Dec 26, 2015 | 10:43 AM
jc1's Avatar
jc1
hey mike I didn't want to keep bothering you. I tried jumper wire on pedal safety switch and nothing, also tried test light on wire on starter relay you talked about for ignition and no power there either.
Old Dec 26, 2015 | 12:56 PM
jc1's Avatar
jc1
hey mike didn't want to keep bothering you, tried jumper wire on pedal switch didn't do anything and tried test light on wire on starter relay and that didn't show any power. radio doesn't work either not sure if that helps figuring out whats going on.
Old Dec 26, 2015 | 03:00 PM
mjr46's Avatar
mjr46
jim acorrding to this diagram and I'm not sure how accurate it is, it also shows a neutral switch but to my knowledge everything is down on the pedal assembly,
http://www.allfordmustangs.com/forum...itchwiring.gif
go down on the column and back probe the wire for the starter relay, and see if it lights up in the crank position...if not it may be a bad ignition switch elec portion...not the lock and tumbler.
Old Jan 3, 2016 | 10:41 AM
jc1's Avatar
jc1
hey mike, just replaced ignition switch still nothing, thought for sure it was the problem old one had a lot of play in it. still have chime when putting key in but no radio tried test light on wire to starter relay still nothing. whats next ? would the pedal safety switch make radio not work too.
Old Jan 3, 2016 | 02:03 PM
mjr46's Avatar
mjr46
grab a test light and check for power at the fuses for the radio with the ign switch to the run position, we need to see what fuses aren't being powered.......possible fuseible link issue if so
Greyhorse35
Mar 2, 2023 03:44 AM
Cee245
SVT Forums
Jan 20, 2016 09:54 AM
91StangOwner
Jan 4, 2016 08:30 AM
Boostaddict
Lethal Performance
Dec 21, 2015 08:24 AM
