help ignition issues
Old Mar 5, 2016 | 06:24 PM
dogggg45's Avatar
dogggg45
Originally Posted by dawson1112
Good then we can rule out fuel issues, cause if it was fuel related the gauge would drop to 0 immediately.
With the TFI I would expect it to buck like crazy up until it dies then have to wait for a while before it would run proper again.
Perhaps the 2 main ecu connections behind the intake are corroded? I would think if they were causing the problem though it would randomly stall or idle funny. Not just after it got warm, but you never know its worth taking a look at.
Do you have a spare distributor you could put in to rule out the PIP?
I just borrowed a dizzy from buddy just haven't had time to throw it in. I actually try those connecters but they're a pain to take apart, broke a clip and figured I'd hold off on it. But I'll check it out tomorrow.
Old Mar 6, 2016 | 06:39 PM
dogggg45's Avatar
dogggg45
it's fixed! it was the distributor go figure
Old Mar 6, 2016 | 07:17 PM
dawson1112's Avatar
dawson1112
I kinda figured swapping the dizzy would solve the issue.
Old Mar 7, 2016 | 08:47 AM
dogggg45's Avatar
dogggg45
Thanks for the help guys. Just gotta double check my timing then I can get back to hurting LS guys' feelings
Old Mar 15, 2016 | 03:07 AM
leftyatm's Avatar
leftyatm
I have an 86 5.0 built 306, tuned already, maf converted. So my problem is the car will run fine but 20 min into the drive when everything gets good and warm, the car will intermittently die. It dies like you shut the key off, engine just stalls out no sputter like a fuel issue, and its not ignition switch it's newer, and it doesn't shut of the radio and accessories. I have replaced the module and module connector already. I resistance tested the coil checked fine, but im not sure how accurate that is because the problem is when everything gets warm. Other than that the only idea is the pick up coil. any ideas which one is more likely?
It sounds like the tfi module to me
Old Mar 15, 2016 | 07:35 AM
88 orangepeel notch's Avatar
88 orangepeel notch
lol,........ but not in a disrespectful way, just lol.
tomcamaro97
Jan 6, 2016 10:04 AM
jc1
Jan 3, 2016 02:03 PM
jot
Dec 22, 2015 12:24 AM
sailorflavor
Dec 20, 2015 04:20 PM
