95 cobra tps voltage high 5.11v in 1.13v closed and wont pass 4.6v sweeps fine
Old 03-21-2016, 02:59 PM
Richard1916
Richard1916's Avatar
Default 95 cobra tps voltage high 5.11v in 1.13v closed and wont pass 4.6v sweeps fine
yes i know there is no adjustment on these cars and people say no benifit to adjust i want to know if it tps needs replaced because of the 1.13v closed and if it is a problem not reaching 4.9v open it hits 4.6 max. or if it is because of the 5.11v feeding it. any ideas?
Richard1916 is offline
Old 03-22-2016, 07:36 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I'd slot the TPS to get voltage below 1.1v at idle. Anywhere between .5v to 1.1v is good.
Your WOT voltage isn't important as the computer reads anythng over 2.71v from the idle readings as WOT.
EDIT: Someone correct me if I'm wrong as I don't know if this is correct for SN cars.
88 orangepeel notch is offline
Old 03-31-2016, 06:00 PM
dawson1112
dawson1112's Avatar
use a drill bit to slot the tps so you can adjust it. Once you can adjust it set it to between .75-.9 volts. Once you do that it will sweep up to the full 5v reference.
dawson1112 is offline
Old 03-31-2016, 11:36 PM
jwog666
jwog666's Avatar
basically it doesnt matter, if your idle speed is good, the tps voltage being .4v off doesnt indicate or control anything as far as strategy goes, the pcm looks at airflow across the maf and adds fuel and adjusts timing based on load. in the field you will almost never see any tps sensor actually get to 5v at wot, it gets close but not 5v, thay give a range as a spec and as long as its in that range, the sensor is ok. if you are trying to fix an issue, and the tps tests within range, messing with it wont fix your issue. here is a detailed setep by step process of how to test a tps, you will notice that the max v never gets to 5v http://www.enduringautomotive.com/tps/
jwog666 is offline
latinheat1018
16
02-13-2019 05:45 AM
faldy54
04-02-2016 09:05 AM
tcpxxx18@gmail.com
03-24-2016 05:47 PM
dennis owens
03-21-2016 08:04 AM
Quick Reply: 95 cobra tps voltage high 5.11v in 1.13v closed and wont pass 4.6v sweeps fine
