Engine codes.
Old Jul 10, 2016 | 07:04 PM
my65coupe's Avatar
my65coupe
Default Engine codes.
Got great advice on my
First post so going to ask another
I have been having check engine light come on and off.
Tested and got 52 56 81 89.
Only on that relates to any issues o have been having is 89
Converter clutch override solenoid. When I come to a stop car surges and want to die.
Has anyone else had this issue and how hard is it to replace. Where can I find the parts also.
Thanks.
Old Jul 11, 2016 | 06:24 AM
dawson1112's Avatar
dawson1112
Your 95 mustang should not be reading out 2 digit codes. The 94-95 cars use a 3 digit code. How are you checking the codes?
Old Jul 16, 2016 | 10:10 AM
Autotech's Avatar
Autotech
Agreed, you should be reading 3 digit codes. Here is how you should be checking them if you do not have a scan tool.
How to check Ford codes without a scan tool
As for swapping out the solenoid, not to difficult at all. Drain/drop the pan and it is right there.
Old Sep 22, 2016 | 10:46 PM
David Weinstein's Avatar
David Weinstein
What an opinion: looking togged a T code 66 coupe, solid, no rust, power steering, ac, but its been converted to a v8--how much does that devalue the car? how big a deal is it? its seems to have been done well--drives well after 94k after the conversion. Im looking for a daily driver, not a show car, etc. does the V8 kill the car by changing it from a t v6?
Old Sep 23, 2016 | 06:50 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Welcome to the forum David, but start a new thread with your question. Highjacking a thread is frowned upon in forums.
stwarrior23
Mar 15, 2016 01:57 PM
shtellon
19
Dec 8, 2003 04:49 AM
93lx50conv
May 4, 2003 11:59 PM
98StANG4.6
Apr 30, 2003 07:27 PM
SHOleen
Apr 4, 2003 06:49 PM
