stock 2.73 to 3.73
RE: stock 2.73 to 3.73
Dont quote me on this but I was told that for every gear ration you go up in your RPM's will increase by 200. So if you are on the highway and usuall cruise at 2,200 you will be up to 2,400 if you went up one ratio. If you go too big they will def. kill your gas milage but its sooo worth it
ok... i was thinkin over the weekend. if i were to do this, is there a tranmission, maybe a 6 speed that has a really low overdrive gear. i was thinkin since i need a new one anyways get one to help compensate for the higher gears.
if i were to do this i would still want to keep the gears i have right now but have a low od gear. is this possible?
6 speed cars have 2 OD gears
if you only get 16mpg in a fox with273 your car is in poor running shape
and your car can be considerd stock. a CAI and exhaust isnt much really.
16 in the city. about 23 on the highway. eventually i'm going to have to get a new one so i figured i could try to kill 2 birds with 1 stone.
i used to get 14 before i got the CAI and the full exhaut with the O/R pipe
mungodrums
09-29-2015 09:18 PM
ccdguy
09-19-2015 05:20 PM
