93 5.0 map sensor
Old 02-16-2019, 12:56 AM
Rudy0131
Rudy0131's Avatar
Default 93 5.0 map sensor
I have a map senor
but it looks like if it has a vacuum line connector
the thing is
I don’t have that hose line
it’s connected
but the hose line is capped
I’m thinking of changing the sensor to a new one
will it make any difference?
or should I leave it there ? Old
Rudy0131 is offline
Old 02-16-2019, 12:57 AM
Rudy0131
Rudy0131's Avatar
Default My post
I
I don’t have egr or smog
Rudy0131 is offline
Old 02-16-2019, 12:59 AM
Rudy0131
Rudy0131's Avatar
I have this set up in a truck
pretty much deleted everything
Rudy0131 is offline
Old 02-16-2019, 09:04 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
it is for barometric pressure, not for fuel. Ford got away from map sensors on the mustang after 88.
TrimDrip is offline
Old 02-16-2019, 09:39 AM
Rudy0131
Rudy0131's Avatar
Default 5.0
so If i add a new one
will there be any difference?
its pretty old 1 year half
Rudy0131 is offline
Old 02-16-2019, 10:19 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
I doubt it.
what difference are you looking for?
TrimDrip is offline
Old 02-16-2019, 11:55 AM
wbrockstar
wbrockstar's Avatar
86-88 models use a map sensor & 89-95 models use a bap sensor.Its basically the same sensor.The only physical difference between the two is a map sensor doesn't have the white collar on it where the vacuum hose port is and the bap sensor does.The collar was added to prevent 89-95 owners from installing a vacuum hose on it.
86-88 models- a vacuum hose gets ran from the upper intake to the map sensor port.....
89-95 models- the bap sensor port is left open so it can vent to atmosphere.....
If you don't have a bap sensor code (126) present and/or symptoms of a defective bap sensor,theres no reason to replace it.The sensors output is used to help the ecu set the correct air fuel mixture.
(Testing)
http://sbftech.com/index.php/topic,19336.0.html
wbrockstar is offline
Jodi Johnson
02-01-2018 01:10 AM
88GTBLACK
10-24-2009 11:16 AM
P44E Emerald Green vert
09-07-2009 09:44 PM
jssblues
08-16-2008 07:33 PM
RUSH2112
04-21-2007 02:52 AM
Quick Reply: 93 5.0 map sensor
