Foxbody Front End trouble
Hello, I have a 91 mustang gt 5 speed. Recently purchased this car for a daily driver. There was obvious front end issues so I dug right in. Replaced the power steering rack and tie rods (which the old were both destroyed, probably not safe to drive) and now the car drives worse than before. I having bad vibration, the car won’t drive straight, it’ll pull either left or right hard, it’s a job trying to keep the car in the lines. Almost hops at full turn extension? Have to rev the car up decently high to get the car going from a dead stop.
I did some reading but I’m not really sure what it could be. Rag joint, ball joint, struts and shocks? I’m not sure. Any opinions would be appreciated, thank you!
CASTER holds the steering wheel in position as the vehicle is moving forward. CAMBER simply places the tread portion of the tire flat on the pavement.
Rear wheel drive vehicles have a slight amount of TOE-IN on the front wheels. This makes the car go straight. It is set by adjustments on the tie-rod ends, something not done on your car.
BASICS! The TIRES determine whether the vehicle tracks straight or ****-eyed! If they are pointed outward (as viewed from above, "TOE-OUT") the vehicle will be impossible to guide in a straight line, as one tire then the other pulls the vehicle to one side, as traction varies. TOE is one of the THREE alignment values, the others being CASTER and CAMBER.
Okay thank you, so it sounds like an alignment will solve my problems?
MrChubs1
07-30-2007 12:08 AM
