are the low 11's in reach??????????
Old 11-26-2005, 11:04 PM
bbfao
bbfao's Avatar
Default are the low 11's in reach??????????
i have an 88 hatch thats stock for now. its going in the garage in 2 weeks to get tore up!!!!!!!!! the mods will be a trick flow top end, underdrive pulleys, 40 lb injectors, a mass air conversion, a 255 lph fuel pump, 3:73's in an eaton, frame conectors, 75mm tb, new h-pipe with flowmasters dumping off, and a new clutch (undecided), and the icing on the cake is going to be either a procharger or kenne belle sc!!!!! with all of this on a new 347 short block from ford racing
bbfao is offline
Old 11-26-2005, 11:28 PM
luckythirteen13
luckythirteen13's Avatar
Default RE: are the low 11's in reach??????????
probably high 11's
luckythirteen13 is offline
Old 11-27-2005, 12:20 AM
SchoolBoy
SchoolBoy's Avatar
The only thing I can find wrong with that list is I belive you can't run underdrive pulley's with a s/c?
SchoolBoy is offline
Old 11-27-2005, 12:31 AM
rsw007
rsw007's Avatar
10's if you can drive. i have a friend with a 331 n/a car running 10.90's weighing in at a mere 2700lbs car & driver.
rsw007 is offline
Old 11-27-2005, 01:08 AM
fordguy17
fordguy17's Avatar
ORIGINAL: luckythirteen13
probably high 11's
come on, a h/c/i 347 with a supercharger?
fordguy17 is offline
Old 11-27-2005, 01:22 AM
86HOGT
86HOGT's Avatar
Yeah I don't think you can run under drive pullies an a KB.
86HOGT is offline
Old 11-27-2005, 04:23 AM
88BlueGT
88BlueGT's Avatar
If you tried hard enough and got a 347 to hook you can take it to the 10's all motor. Ive seen it done plenty of times. And with a blower?!?! I dont think I need to say anymore...
88BlueGT is offline
Old 11-27-2005, 09:50 AM
stanglx2002
stanglx2002's Avatar
you shouldnt have any problems getting into the 11's with that combo as long as you have a good suspension that you can hook up on bc without a good suspension you have nothing
stanglx2002 is offline
Old 11-27-2005, 10:21 AM
luckythirteen13
its a good set up, just need traction and to drive it hard and youll be fine
Old 11-27-2005, 11:07 AM
vfast
I ♥ Acer
vfast's Avatar
it won't go anywhere........................y see below
because they don't make 40# injectors and they would be way too big..the car might not even start
vfast is offline
Quick Reply: are the low 11's in reach??????????
