How does Lunati compare with Comp? I was thinkin bout doin a comp cam instead of an alphabet cam, but there are so many dam cams to choose from. I want a cam that will maximize the heads that i get, and also be okay for a Kenne bell, any suggestions for a Lunati cam?
lunati is the best hands down. OnyxCobra call lunati and see what they think you should use, if they dont have an off the shelf cam for you they will make you a cam for what you want.
no kiddin? I was also lookin at the trickflow stage 1, i like the specs on that. I guess i cant go more than .550 lift w/ the heads, so with my 1.7 rockers that limites me to a .512 cam lift. I dont know if the upgraded springs are going to help with that or not, im not too familair, but they say valve float is possible over 5800rpm so i wanted to do the stiffer valve springs. Does that help with how big of cam lift i can go? What are your thoughts on that?
