milling stock heads?
how much horse power would I get if I had the heads milled so the compression is up to 10.5.1 ?will the stock internals hold up, is this worth it, Im staying N/A, so is it worth the power gain. will there be any P/V clearance probs?
RE: milling stock heads?
sorry but for a typical 5.0 HO motor. a rise in .5 of CR is = to 15hp. so if he goes from 9.0 to 10.5 that would be 3x15=45 so yes in theroy it works. and if you dont believe me do some searching before doubting me. for a better source of looking look in the Offical Ford Mustang handbook. i could get technical and post page,paragraph and sentence of the fact but ill leave that for you to find yourself
im pushing awfully close to 11:1 on my 306 runnin on 94 and 93 with timing up in the 16 18 degrees on gt-40 irons shaved .040 and my p/v is fine and my intake sits fine
when that motor gets hot after a while and i got to start it back up it has a bit of trouble firing back up heat soak and what not but
it just is picky and the compression is nice and what not plenty of ***** and stuff just dont go to high if you do it will be completly crap for a true street car id say 10.5 is the max
Mine crept up to 11:1 by accident with the mods i made and its not even outta the hole on the block zero deck with forged flat tops with reliefs
i just had mine milled 40thousands and they said mine would be around 10:1 but they said they wouldn't recommend going nemore than that cause of pvc and if it over heated the heads would be done for
