Holley Blue Fuel Pump and Regulator
Does anyone know what the regulator is pre set at when you take it out of the box on the holley fuel pressure regulator? I have read you should set it to around 7psi. I didnt want to start the car with 14 psi going into the carb if the regulator wasnt preset. Thanks, Dave
RE: Holley Blue Fuel Pump and Regulator
I've been using those things for years.
All of them I've ever had would be 6-7 psi out of the box.
When putting on car to fire -up just hook fuel pressure gauge to it for makin' real sure..........
