What weight gear oil for T-5??
Hey all I'm getting ready to start my T-5 conversion and all I'm lacking is fluid. I'm going with redline, but what's a good weight to go with. Summit has 75W90. Is that good or would you all recommend something else?
RE: What weight gear oil for T-5??
I was thinking ATF would work as well but I just wanted to see what everyone was running since the gear oil says you can put it in a manual too. Looks like ATF it is. Thanks for the knowlege everyone.
because of the sycros used gear oil would slow them down to much!
ORIGINAL: Tims 88GT
you are supposed to run atf in a aluminum case trans. that is what i was told.
musnicki
09-23-2015 07:11 AM
09-08-2015 11:50 AM
