fuel pressure and timing advance
12-21-2005, 01:57 AM
89 mustang 5.0 gt 40 heads,gt 40 intake,bbk headers,bbk 75mm throttle body and egr spacer,75mm pro-m mass air sensor,24lb injectors,190lph fuel pump,adjustable reg.
need to know a good fuel pressure setting and timing advance
12-21-2005, 02:49 AM
RE: fuel pressure and timing advance
12* and 32lbs I heard was a good setup, 14* with Premium gas.
12-21-2005, 02:59 AM
try 38-40 .
12-21-2005, 11:31 AM
alll cars are different it just depends on if your car is running rich or not
12-21-2005, 12:00 PM
best to set the fuel pressure on the dyno to get proper A/F ratio, otherwise it is just a guess.
12-21-2005, 12:30 PM
Quote:
ORIGINAL: crazyhorse
try 38-40 .
Isnt it different with 24lbs?
12-21-2005, 07:40 PM
thanks for the replys running 39psi for fuel 14 degree advance seems to run good like that
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
MEISTERSNFB
03-31-2020 07:50 AM
yurizx6r
09-07-2015 06:40 PM
timeformiller44
08-26-2015 12:03 PM
50 ,
50l ,
89 ,
advance ,
advnce ,
drag ,
fuel ,
gt ,
increased ,
liter ,
mustang ,
pressure ,
racing ,
setting ,
timing
