Trick Flow "R" package?
Hi guys, a friend of mine is planning on a 331ci engine topped with Trick Flow R series heads and Intake, cam spec: 236 intake/248 exhaust .359 in./.372 in. .574 in./.595 in. 110 lobe sep.
Compression Ratio: 10.1
long tubes, H pipe, cat-back.
How much power can he expect?
Thanks.
Thanks.
5 million hp.
we cant tell you anything about hp numbers every combo is different. and different tunning results in different power and also the atmosphere has to deal with power figures
no clue...to many other things you left out ..and if this is a street car and that's a roller cam..it will not be very friendly on the street and with the tight c/l vacuum will be low and a vacuum can booster will be need for the brake
mungodrums
Suspension
02-09-2016 09:05 AM
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
