loose balancer
i was at the dyno and they said my balancer was loose and it was throwing off my timing and i was detonating at a high rpm so they turned it down and they cant tell me what timing* degree im set at cause of my balancer. i Should've asked ther, but whats a balancer? should i get a new one ASAP?
i dont know about the fox bodys but the 1st gen stangs the balencer is two pieces with a rubber ring sandwiched in between them and the outer ring can slip causing minor imbalence and the timing marks to be off and u can get a high performance balancer ex fluidampner 1 piece fluid filled for balence!
ORIGINAL: Black Snake
If your balancer was loose wouldnt it cause you engine to vibrate like crazy?
jessicarabbit
Sep 25, 2015 12:41 PM
LivingInThePast
Sep 16, 2015 12:20 PM
