Flywheel
Old Jan 14, 2004 | 10:06 PM
Milky's Avatar
Milky
Default Flywheel
I recieved an aluminum flywheel as a gift and wonder if it is an imporvemnt over the steel. Ive heard steel is better for the daily driver and occasional racer and aluminum is more for the dragsters... am I wrong?</P>
Thanks</P>
Old Jan 14, 2004 | 10:55 PM
primetime5.0's Avatar
primetime5.0
Default Flywheel
ive heard the aluminum is more for road racing and the stocker is better for dragging but who knows
Old Jan 14, 2004 | 11:01 PM
Milky's Avatar
Milky
Default Flywheel
Well, I'm debating whether or not to put it on ebay or to use it on my car...
Old Jan 14, 2004 | 11:02 PM
hotrodman's Avatar
hotrodman
I ♥ Acer
Default Flywheel
hell your motor will rev up a lot quicker.
Old Jan 14, 2004 | 11:05 PM
Milky's Avatar
Milky
Default Flywheel
Naturally, but id figure the steel might give it momentum or something. let me know if im wrong.
Old Jan 15, 2004 | 03:17 AM
nemethjames1's Avatar
nemethjames1
Default Flywheel
ok, if you went to aluminum, it would tach up faster, and in first second and third it would be more snapy.. but as your getting up to speed you will notice that it doesnt have the same ammount of force it did with the steel... all in all if you want it quick off the line an aluminum flywheel is a good start... but for longer distance racing i would stick with the steel... how much hp is your motor pushing anyways? if its alot more then stock then for sure go with the aluminum!
Old Jan 15, 2004 | 03:35 AM
Milky's Avatar
Milky
Default Flywheel
Im putting out about 350 at the wheels right now, give or take... So Im not sure which im going to do.
Old Jan 15, 2004 | 06:14 PM
mkspeed26's Avatar
mkspeed26
Default Flywheel
the steel will give you a smoother running engine. with the aluminum the rpms will hang more (when you get up into higher rpms and let of the gas). aluminum will be a little lighter so it might save you a few pounds.
6bangr
Feb 15, 2016 07:40 AM
junior04
Sep 28, 2015 10:53 AM
dudeguy421
Sep 24, 2015 11:16 AM
ccdguy
Sep 19, 2015 05:20 PM
ponyride00
Aug 12, 2015 01:57 PM
