Question about alternator
Yea I did do the splicing of the stock wires like the directions said and that helped with the startup but it is still draining a lot of power even when I'm driving if I turn on a couple things at once such as the heater and lights or heater and blinker, etc...
there has to be a bad connection somewhere whether its a loose wire or what not, i had a similar problem in my winter car with my system but my problem was with lights n sytem an ish it would overloaded the alternator and bend my pulley if your serious about a system invest in a quality capacitor to only supply juice to the system when it needs it so it doesnt put extra work on the alternator let me know how you make out
i had the same excact problem... new alt and battery turnd out when i got my alt tested it was running 9 out of 14... so go get yours tested at auto zone or somthing i gaurentee thats it.. or its your voltage regulator
well there are 2 ways to do it... if you drive up there they can test how many amps your alt. is giving off while your car is running ect... or if you take it you and there they can test if its plainly good or bad.
Golfsito
10-06-2015 11:02 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
