CAMS
Old 12-28-2005, 06:50 PM
vfast
I ♥ Acer
vfast's Avatar
Default RE: CAMS
my e-cam is here for ya
vfast is offline
Old 12-28-2005, 06:54 PM
88BlueGT
88BlueGT's Avatar
Default RE: CAMS
I thought that you sold that thing a long time ago, why dont you throw it up on ebay?
88BlueGT is offline
Old 12-28-2005, 07:31 PM
OneFine89Mustang
OneFine89Mustang's Avatar
Default RE: CAMS
i just bought the trickflow stage 1 cam is anyone else using this cam how does it sound?im putting it in next weekend i wanted to see how people like it?
OneFine89Mustang is offline
Old 12-28-2005, 07:39 PM
schwindty
schwindty's Avatar
Default RE: CAMS
Let us know how you like it, I am going with that cam as well!
schwindty is offline
Old 12-29-2005, 04:22 AM
5.0FoxBody
5.0FoxBody's Avatar
Default RE: CAMS
Hey...that cam for sale...how well will it go with a fairly stock 5.0 and AOD??...w/ the mods in my sig..
5.0FoxBody is offline
Old 12-29-2005, 01:29 PM
88BlueGT
88BlueGT's Avatar
Default RE: CAMS
Its only a Stage 1 cam, you would be fine.
88BlueGT is offline
Old 12-30-2005, 01:03 AM
tinman
tinman's Avatar
Default RE: CAMS
OK, if cam ia realmaggressive, say over 228@.050 it will make very poor torque. Auto trans don't like this so we use a high stall convertor.
What to shoot for is a 'vertor about 2-300 stall UNDER the max torque of engine. Vertor will flash above the max torque point of engine anyway so don't worry about it.
Run too much stall and lots of slippage will happen so don't get carried awy.
Lots of other factors here like stroke of engine, carb or throttle body size, tire size, conditions, etc......
tinman is offline
Old 12-30-2005, 01:06 AM
cammedlx
cammedlx's Avatar
Default RE: CAMS
ORIGINAL: Cantcatchme
Look into Comp cams they are just awesome, go no lower than .608 on the lift and you will be fine
Ummm.....yeah...Can you say piston to valve clearnce problems????And i said it a thousand times a cam with stock heads and otherwise a basicly stock motor is 100% pointless.
cammedlx is offline
Old 12-30-2005, 04:35 AM
Jared_blown5.0
Jared_blown5.0's Avatar
Default RE: CAMS
sry stang96 i giess i didnt get the memo that afr heads were stock heads. my bad thanks for saying it the thousand and first time for me.
Jared_blown5.0 is offline
Old 12-30-2005, 04:48 AM
Crazyfast50stang
Crazyfast50stang's Avatar
Default RE: CAMS
great article
Crazyfast50stang is offline
Quick Reply: CAMS
