Motor mounts
#21
RE: Motor mounts
They help by stiffening up the drivetrain, especially compared to worn out, marshmallowey stock mounts. They are not very difficult to replace with common tools. In summary, you just need to support the motor while swapping them. You can do this with a jack and a board under the oil pan.
#24
RE: Motor mounts
It wouldn't hurt, but you can be pretty exact with a floor jack if you're slow enough lowering it down. You really don't need to lift the motor much, just enough to support it. Then you can swap them out relatively easily.
#26
RE: Motor mounts
Just a reminded, ProMustangPerformance is your #1 source for Energy Suspension Polyurethane motor mounts
jwog666
12-27-2021 08:09 PM
logan409
09-26-2015 07:43 PM
