damn car still missin
it's still missin, and it has made me lose some bottom end power, seems to pull decent on the top end, it has a slight shake to it at idle, and this is a pain.... i ordered a new m.a.f. sensor, does that sound like it could be the problem, i can't scan it cus the stupid jet chip on it... any advice would help, p.s.-my buddies 93 h.o. is havin the same problem
RE: damn car still missin
well i put new injectors fuel pump and filter on, knowing that my ignition module and distributer are all good, so it has spark and fuel, but it could be the tps.... peddle does seem to act a lil goofy, i dunno
i do have a multi meter... i will check it... oh yeah i checked the coolant temp. sensor as well the other day.. hope to figure it out soon... cus it stinks not havin it run rit...
Check all these. The haynes manual says to go over this stuff if your car is missing.
A) Fuel filter clogged or impurities in fuel system. Clean system and check fuel filter.
B) Faulty or incorrectly gapped wires.
C) Incorrect ignition timing.
D) Cracke dist. cap disconnected dist. wires or damaged dist. components.
E) Defective sparkplug wires.
F) Emissions systems components faulty.
G) Low or uneven cylinder compression pressure.
H) Weak or faulty coil.
I) Weak or faulty ignition system.
J) Vacuum leaks at intake manifold or vacuum hoses.
K) Dirty or clogged fuel injectors.
L)Leaky EGR valve.
M) Fuel injection or engine control systems malfunctions.
L)Leaky EGR valve.
92 5.0stang
08-13-2015 06:46 AM
Soldier GT
08-12-2015 03:46 PM
Milan Dragway
08-12-2015 03:43 PM
