vacuum leak
Soooo! turn your idle down. What is the problem, you say vacume leak as a topic and post a sentance dont be shy. Need more info on what you have, whats wrong and what you have done. Replacing all the vacume lines that you can see is a start
do you have any mods done? Intake manifold? cam? heads? Speed density cars dont adjust well to even the slightest things....you would be suprised! Had an 87 that had a typhoon upper and lower intake....idled around 1200
Yea a Vacum leak will raise your idle, just pull off the first line off the tree and watch your idle peak. If I was you bro, I would take the upper intake off get some new gaskets and new hoses and see if that works.
bradleyb
Nov 27, 2015 07:50 PM
