car won't start.
Old 01-16-2006, 11:51 AM
moose87
moose87's Avatar
Default car won't start.
it has been very very cold here. i started the car up last night aroun 10 pm and it was fine. i came out this morning around 830 and it cranks but won't start. will a jump fix this problem? the car is currently on the street and I needto get it to a garage, so any help on starting it would be greatly appreciated.
moose87 is offline
Old 01-16-2006, 12:05 PM
moose87
moose87's Avatar
Default RE: car won't start.
i'm assuming a jump won't start it since it cranks. i've heard of using a spray can of ethanol (sp?). sorry for what are prob stupid questions, i have never had this problem with a car befor...
moose87 is offline
Old 01-16-2006, 06:37 PM
Grimace5.0
I ♥ Acer
Grimace5.0's Avatar
Well, there are about 5 zillion things that it can be.. LOL
Does it have spark?
Does it have gas?
I'm ASSuming it turns over since you said it cranks.
Grimace5.0 is offline
Old 01-16-2006, 09:04 PM
RabidSmurf
RabidSmurf's Avatar
if it doesn't crank fast enough it might not start, I've had that problem many times. If you have a old worn out distributer cap and rotor the speed at which the starter cranks the engine could play a huge roll in wether or not it will fire. I'de try jumping it first, if that don't work plug in your block heater for a few hours (assuming you have one). And try it again. If it still doesn't work after that, I'de assume either your gas lines are frozen (not likely unless it was like -60) or the unlikely chance something is wrong with your ignition system or fuel system. But you said it started the night before no problem, so it's probably something to do with the cold, a weak battery providing a weak spark is my guess..
RabidSmurf is offline
Old 01-16-2006, 09:17 PM
marx91
marx91's Avatar
could be a bad fuel pump they can just up and die on you, turn the key forward
without starting it and see if you can hear the fuel pump kick on
marx91 is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
drumhedd2005
08-13-2015 09:59 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
'stangdude
08-12-2015 01:27 PM
Quick Reply: car won't start.
