Head porting advive
Old Jan 21, 2006 | 10:52 PM
davemurray's Avatar
davemurray
Default Head porting advive
http://www.sa-motorsports.com/diyport.shtm
http://www.diyporting.com/
Old Jan 22, 2006 | 12:23 AM
fats429's Avatar
fats429
Default RE: Head porting advive
this ant as hard as it sounds it just takes foever to do heare is my links
http://www.jason.fletcher.net/tech/f...a/castiron.htm
http://www.workmonster.com/index.htm
http://hometown.aol.com/valakoraceheads/page11.html
thats just a few pm me if you need more I will shoot you a e mail .
Buy the video in the link it will help alot to watch sombody els do one first . SA is a suplyer for the tools you will need . flech's link will show you flow data that will get you a IDEA of what you are trying to acheave
Dont use good heads untill you can see how fast the meaterial comes off and how hard to push . Eaven stock heads are good heads get dead ones from the junk yard first
WHY BUY HORSE POWER WHEN YOU CAN BUILD IT
Did my first set last year and was very happy with the power gains
ford muscle has a fourm on home porting http://www.fordmuscle.com/phpBB/
Old Jan 22, 2006 | 12:35 AM
vfast's Avatar
vfast
I ♥ Acer
no it isn't hard you just have to know what your doing as doing a back yard port job like just hogging things out will make to car slower ,have idle issue and uneven combustion..you want every port the same
Old Jan 22, 2006 | 11:11 PM
tinman's Avatar
tinman
I would use air power die grinders, several. That way instead of changing the tool in the grinder, you just go to the next grinder.
Sandpaper rolls are a very good idea for port matching.
Take your time
You'll want a good face shield, some gloves and some paper masks.
BTW, a 100cc burret is a good idea so you can measure where you started and where you are.
Take your time.
The last set I did were for a 440 Mopar. Took about 45 hours.
Got me .25 seconds off the ET.
I've been doing them off/on for nearly 30 years.....
Old Jan 23, 2006 | 09:20 PM
davemurray's Avatar
davemurray
Thanks for all help
I just started working on my first head, Gasket matching the intake ports.
Tomorrow I'll start on the exhaust ports wich seems to be a hard work.
How much HP gain could I specte from a medium skilled head job?
I already ran 14.4@98.6 with minor mods on stock heads.
Just want to keep up the good name of mustangs where I live!
Old Jan 24, 2006 | 12:38 AM
SD_LX_5.0's Avatar
SD_LX_5.0
does anyone have any advice for the intake manifolds as well? I purchased an air powered dye grinder and a Sandard Abrasives delux porting kit and im about to start porting my uppers and lowers plus the cylinder heads. i would like to also put roller rockers, lifters and a new cam in, is there anything i should know or will have to do computer and tuning wise? as of now I have bbk shorties with two chamber flows and a bbk CIA, and the car is a five speed 92 lx with 308 posi. Any help? sorry for the random and out of order info on the car i was just tring to tell you all what you might need to know haha.
Old Jan 24, 2006 | 09:03 AM
stanglx2002's Avatar
stanglx2002
port match the intake also. What intake are you planning on porting
Old Jan 25, 2006 | 04:01 AM
SD_LX_5.0's Avatar
SD_LX_5.0
just the stocker, i'd like to snag a gt-40 but a guy at this mustang shop where i live in SD said that the explorer's intakes are missing an egr hook-up that wouldnt let me pass cal. smog. i dont know if this is entirely true but i figured i wouldnt mess with it.
Old Jan 25, 2006 | 04:39 AM
opie1's Avatar
opie1
probably true coming fron someone who is trying to sell you something, sounds like he's just an honest guy(although i dont know myself) you are not going to be able to do alot on the upper intake but the lower intake matched to the heads will see an increase even more so if you have some light to moderate porting on the heads. debur the heads(take the rough edges off intake and exhaust) and port match intake and exhaust. even the factory replacement gasket will show some type of difference in the matching of one or the other. DONT OVER PORT! water jackets(at a severe point of over portring) will become an issue. also a head thats ported too much will not make enough low end power to get you off the line unless you up the compression, boost, or N2O
Old Jan 25, 2006 | 09:48 AM
MachSp33d's Avatar
MachSp33d
Yeh sounds pretty complicated. Sounds like alot of work, so if I need anything ported (like heads) Ill take it to a speed shop. I could probley do the intake manifolds but as well, ill be taking them to a speed shop. My buddys dad dose it, but he says he wants 250$ for a intake manfiold job. Is that to much?
-MachSp33d
