subframes
Old Jan 31, 2006 | 12:37 AM
Crazyfast50stang's Avatar
Crazyfast50stang
Default subframes
Quick question. Will these in any way make the ET go down? I'm finally going to a track this coming month and I want to get those before I go but is it woth hussling to get them on before the track or no?
Old Jan 31, 2006 | 12:40 AM
1990mustanggt's Avatar
1990mustanggt
Default RE: subframes
I have read that sub frame connectors can help at the track due to helping keep the car from twisting. Thats all I know. Wish I could help out more.
Old Jan 31, 2006 | 12:47 AM
Blue Oval's Avatar
Blue Oval
from a physics point of view, the stiffer frame should help the rear bite harder and give you a lower 60' and should improve ET despite the increased weight
Old Jan 31, 2006 | 12:48 AM
Crazyfast50stang
Ok cool. I think I will get the blue oval industries black powder coated ones. 60 shipped.
Old Jan 31, 2006 | 12:51 AM
Blue Oval's Avatar
Blue Oval
i think you might be happier with full lengths for $40 or $50 more
Old Jan 31, 2006 | 12:52 AM
Crazyfast50stang
also I am getting new sparkplug wires, again, cause the old ones melted.... but do you guys think that 25 ft of wire cover is enough?Its 40 dollars for this and I dont want to buy two if I dont have to.
Old Jan 31, 2006 | 12:53 AM
Crazyfast50stang
im kind of on a tight budget and I need to get the wires. How much of a difference will there be with full lengths?
Old Jan 31, 2006 | 01:06 AM
Crazyfast50stang
Also I know this has been asked but accel or MSD? I have the MSD cap and rotor but if I dont have to spend the extra 10 then I rather put it towards something else. Also the accel are made to withstand the heat and supress arcing so I wouldnt have to buy the wrap also.
Old Jan 31, 2006 | 01:10 AM
kartracer55's Avatar
kartracer55
Probably MSD... have you ever thought of getting just braided steel wire wrap? Guys run them on 125 karts... its braided steel wil an insulator layer/coating inside
Jim
Old Jan 31, 2006 | 01:15 AM
Crazyfast50stang
I looked at the braided ones and they are rated F ( up to 450 degrees) and I looked at part number ACC-8033 and they say they are good for up to 550.
