fuel sender gasket?
fuel sender gasket?
how much is a fuel sender gasket and how hard is it to install?
im lookin at a 93 LX and it needs a fuel sender gasket
he also said it seeps up on fill-up? not sure what he means by that but dosnt sound good
let me know
thanks
let me know
thanks
RE: fuel sender gasket?
what the hell is a fuel sender gasket? is he talking about the gasket/seal inbetween the filler neck,and gas tank?
don't be so inpatient...besides you posted it when most of us sleep....
ya sorry i am in patient
ya its some kind of seal/gasket between the fuel tank. how much would a mechanic charge to put a new one in?
hes gotta drop the tank, check the straps and bolts for rust. take off the old gasket (if its even there) and replace it then put it back together. $100 sound fair??
not sure if i said it already but its for a 93 LX 5.0 its got 150k miles but the body is in very good shape and there is little to no rust that i could see from the pics (he sent me like 40 pics, very detailed)
lol how much you think then?
normaly I would have my dad fix it for free but we're not on good terms at the moment.
if you wouldn't mind writing up a little detailed tutorial I'll give it a shot. i have no idea where **** is located on mustangs though. me and my friends look like the 3 stooges whenever we attempt to fix things lol.
thanks man
thanks man
lets see...safety first)unplug inertia/impact switch.start car till runs out of fuel in sys.
dis. battery.
put car on stands
dis hoses to fuel filter/replace filter
open gas lid three bolts there.
gets some nut buster/wd-40..spray the shi@ out of those strap bolts.
loosen them becareful you got your fuel pump/fuel sending unit plug ins above the tank
can't unplug them unless you have some small hands
i sprayed wd-40 around seal,and filler neck comes apart easier.
once you seperate those two clean it real good,and replace with new seal.
put a little wd-40 on new seal so it wont tear when reinstalling
any questions just ask.
dis. battery.
put car on stands
mrappe
09-26-2015 10:16 AM
