intake gaskets
Old Feb 6, 2006 | 11:58 PM
5.0forever's Avatar
5.0forever
Default intake gaskets
I am going to be installing a new upper and lower edelbrok performer intake and was wondering if special gaskets are needed for use with stock heads?I would love some new heads as well but $$'s dont flow like they used to.Also i am possibly going to be installing some 24# injectors to go with my new 70mm tb and 73maf but the maf is calibrated for 19# injectors.How easy is it to recalibrate the maf for 24# injectors??Sorry about multiple questions.
Thanks....
Old Feb 7, 2006 | 03:11 AM
5.0forever's Avatar
5.0forever
Default RE: intake gaskets
ttt...
Old Feb 7, 2006 | 03:14 AM
Black Snake's Avatar
Black Snake
Special gasket for the upper yeah you do. For the lower that bolts up to the heads no you dont, just use felpro gaskets.
Old Feb 7, 2006 | 04:55 AM
5.0forever's Avatar
5.0forever
I figured i could use regular one's for the lower intake,but i have a friend who thinks he is a master mechanic and says different(you know how that goes lol).Thanks for your input.Later
Old Feb 7, 2006 | 02:42 PM
fordguy17's Avatar
fordguy17
when i did mine i just got a felpro kit. it had the gaskets for the upper-> lower and lower->heads as well as an o-ring for the dizzy and the lifter valley gaskets.
also-there is no need for 24lb injectors with a stock motor. stick to the 19's till you make some more power.
Old Feb 7, 2006 | 04:31 PM
gspfunk's Avatar
gspfunk
I'm w/ fordguy....you don't need more than 19's right now. You can make close to 300hp to the wheels w/ 19's.
Depending on what MAF you have, it has to be sent back to the manufacturer to re-calibrate it. If it's C&L, you could buy a different sample tube.
Old Feb 7, 2006 | 06:54 PM
88BlueGT's Avatar
88BlueGT
When I changed the gaskets for my performer rpm they told me that I need edelbrock gaskets. So I had to order them from a local performance shop.
88BlueGT's Avatar
88BlueGT
They might have lied to me but I got them anyway.....
daltron
Apr 28, 2016 08:10 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Dathan
Oct 5, 2015 05:52 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
