what mods should i do next
i have a 94 5.0, i have a 92 bottom end being built forged pistons, i also have a ported heads with bigger valves and a cam going in i think its 220 224 533 544 114LS, its going to be 10:1 comp. i have a bbk cold air intake msd blaster coil, bbk shorty header 2.5 h pipe with no cats,3.73 gears
what should i do next im thinking intake, but would like to here what you guys think.
i could get a trick flow R intake for 500 buck but i dont know if it would work well with my setup
thanks
thanks
RE: what mods should i do next
Is the R intake the boxed upper? if so, stay away from it unless you will be boosting soon. Go w/ the track heat and get a larger MAF (assuming you still have stock).
Also, be sure you've upgraded your valve springs...the stock springs won't like that amount of lift
The TB is definitely worth doing, but only if you've upgraded your MAF...other wise your just making a bigger opening (bigger TB) behind a restricive stock MAF.
JD's Performance has Pro-M 75mm's for $159 (now PMAS). Call them if it's not listed the same on the website. I just bought mine in January.
