WHAT?
WHAT?
the only vacuum lines you need are brake booster and htr. box if you are running heat, as far as wiring remove inj. harness, the easiest way to then get ignition is msd and msd distributer just plug it in.
WHAT?
Originally Posted by mkspeed26
if your state requires you to keep PCV and EGR, then there are a few more things you need to keep. but you can pretty much just toss the rest, or sell it.
WHAT?
Originally Posted by 619socalstang
the car is a toy.
then all you really need is NOTHING!! actually, it depends on if you are using vacuum or mechanical advance on the distributorand carb. vacuum needs lines. </P>
WHAT?
yaeh yeah but what about the big loom on the fire wall that goes to the injectors and stuff, no other critical stuff for lights or anything else in there. as for fuel hotrod im buying a full kit from summitt and a 16 galon cell, check it out tell me what you think.thanks
