Mass Air question?
RE: Mass Air question?
ORIGINAL: RawGtPower
Im thinking about getting AFR 165's. will these be good heads with my E303, and will i have to worry about piston to valve clearance?
and
You should be okay w/ the 165's, but the 185's have 2.02 intake valves and they'd probably hit.....
FYI: The E cam w/ 1.7's has a max lift of .529 and it's .535 w/ 1.72's.
I have a 94 gt with with CAI 65mm TB and trick flow track heat intake and 24lb fuel injectors. Would a Pro-m 75mm MAF be a good idea for this combo, and its going for $206.00 on JDSperformance. Is this a reasonable price?
I don't remember the guy I talked to, but all 3 times I called them, he answered. I think his name is David, but I'm not sure. They used to list it for 159, but he said that PMAS was making dealers show their list price like MSD does with their stuff, so he might sell it for less, but he wont BS you so give it a shot.
id say if you're planning on doin a blower might as well get a larger injector now, say 36 or 42 since ur maf has to match. and yeah E303 with 1.7rr and AFR 165s work fine together, my friends fox went 11.8 on slicks with that heads/cam combo and 3.55 gears...
