TPS questions
TPS questions
I was out trying to check the voltage at the TPS on my 94 GT and found that I don't have a green wire to test. My wires are brown..gray/white...gray/red Also I didn' get any readings at all.KOEO with my DVM. It could have been a bad probe on my part. And how in the f#$% do you get to the ataching screws? Do I have to take the IAC off?
Thanx for the input
RE: TPS questions
ORIGINAL: OnyxCobra
dont think its on top of 94/95s... There is nothing ontop of my TB.
i know the SPOUT is at the fender...but i messed w/ my buddies '95 and from what i remember it was there.
RE: TPS questions
These are the screws I was talking about and the location of the TPS behind the IAC
[IMG]local://upfiles/26172/C041A8F60F444241833698223CF5F488.jpg[/IMG]
[IMG]local://upfiles/26172/0ADAF8CAA81F44F6B1509C2CF34FB71D.jpg[/IMG]
RE: TPS questions
Yup....you would have to remove the IAC....not much to adjust though, the screw holes aren't that big. You might want to also check this '94 wiring diagram (courtesy of TMoss and veryuseful.com) so you can id the wires correctly. GL
PS: If you want to make sure you're following the right setup for the KOEO scan, check this DIY procedure, it also hass the links for the 3-digit codes definitions....again, GL
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
