TPS Issues
Old Jul 2, 2007 | 05:14 PM
shawnk007's Avatar
shawnk007
Default TPS Issues
I tried to adjust my TPS today, and when I put my voltmeter on the green wire, Im only pulling .11 volts. I tried to adjust, but was only able to bring it up to .15 volts. Does this indicate a bad TPS? At the red wire, I only have a constant 5.2 volts, is this low or normal? I ping alot at wide open throttle with 92 octane and 12 degrees timing. So, Im assuming my TPS is causing me to run lean. Any ideas?
Old Jul 3, 2007 | 02:13 AM
shawnk007's Avatar
shawnk007
Default RE: TPS Issues
bump
Old Jul 3, 2007 | 02:28 AM
iceman89gt's Avatar
iceman89gt
replace the tps, mine did the same thing 2 days ago just before i went to race and it was the tps. i was wondering why i couldnt calibrate it. turns out that after i slotted it the screws sank too far down into it and damaged it. the new one without slotting reads 1.00 and it cured my problems.
Old Jul 3, 2007 | 04:53 AM
AdderMk2's Avatar
AdderMk2
Banned
you should only have 5v source voltage at the TPS, however .15 volts is WAY low.... replace it
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
