thoughts on this combo
#21
RE: thoughts on this combo
ORIGINAL: ozz
so i am gonna head and go with this set up but when i buy the intake i am also gonna get a 70mm throttle body can i get my stock maf calibrated to the 24 lbs and 70mm tb or do i havce to buy a new one
buy an SN-95 maf and get a chip for the car that will alter your injector high and low slopes to accept 24# injectors
#24
Here is a link to a page I found today that helped answer some questions I had about MAF's
http://www.graphicsdept.com/walbro/p...mass/forda.htm
I had 2 MAF the one I got off a 90/91 Mustang Stock
E9ZF-12B579-AA
AFH5503
And one I bought on e-bay that is 70mm and suppose to be for #24 injectors
F1ZF-1213579-AA
AFH5503B
What I found from that site is that they both are for #19 injectors when applied to a Mustang
the one you would need for #24 is
F1SF-12B579-AA (93 Cobra)
AFH70-02
or
F2VF-12B579-A2A (94/95 Cobra)
AFH70-04
On a different message board I found on the same search shows that different models can use the same MAF module.
hope this is helpfull
E9ZF-12B579-AA
AFH5503
F1ZF-1213579-AA
AFH5503B
AFH70-02
or
AFH70-04
This is what I copied and pasted to a text file for reference, it was posted on an ebay listing. I only assume the info is correct.
Ford pt# is F1ZF-12B579-AA. According to my cross reference, this meter will fit the following vehicles:
1988-1993 Mustang 5.0L (except Cobra and `93 California)
1991-1993 Ford Thunderbird & Mercury Cougar w/5.0L or 3.8L (except `93 5.0 California)
1989-1990 Ford Taurus w/3.0L
1991-1995 Mercury Sable w/3.0L
1991-1995 Ford Taurus & Mercury Sable w/3.8L
1991-1995 Taurus SHO
1991-1994 Lincoln Continental w/3.8L
#27
ORIGINAL: my77stang
jesus f*cking christ the depth of arrogance and/or stupidity in this section can amaze me
@ the OP I too am in college and decide to just wait it out until I can afford the good stuff [8D] If you HAVE to go alittle faster, try finding an explorer 5.0 in the junkyard, (Heads and Intake) can be had pretty cheap, pick up a decent cam(TFS1) and your set
#28
ORIGINAL: AdderMk2
hrmmm ... something tells me YOU got screwed
ORIGINAL: raven_ghostwolf
F1ZF-1213579-AA
AFH5503B
F1ZF-1213579-AA
AFH5503B
But hopefully now others can benefit from the info I posted here.
