mahle pistons
RE: mahle pistons
I have Mahle's in mine, they are VERY good quality, very strong, and very light weight. However, a piston/ring package starts at around $600 and just goes up. It depends on what you wanna do. If you wanna use boost/spray and not have to worry about pistons(as long as you don't detonate and fry them that is) then Mahle's, or others are good. For a mild budget build they may be waymore than you need. They are a good weight saving piston though. I'm running SBC stroker pistons and 5.7" Scat SBC rods though, so the piston/pin setupI'm usingis 85g lighter than the Ford 5.09 rod pistons also from Mahle
RE: mahle pistons
mahle pistons are amazing! they are manufactured in germany. they make pistons for ferrari and various other high performance including Formula 1 cars.
my dad was just there... so i got a nice ferrari piston. lol good stuff. i'm going to get them when i rebuild my engine
RE: mahle pistons
thanx for the info. im planning on doin an NA 331 with Scat forged crank and H-beam rods, not sure on if i wanna spray tho. ill prolly end up goin wit the mahle pistons even tho they are pricey.
RE: mahle pistons
If you're going with a forged crank/rods might as well get really good pistons like the Mahles, then if you do go spray you don't have to worry about a flimsy piston. You'll need a ring filer though, all their piston ring packs are file to fit, and make sure if you plan on doing boost or nitrous that you give them enough gap
RE: mahle pistons
If money is not an issue you could go with these. They are excellent.
http://www.diamondracing.net/home.asp
