Ordering my DOT approved Drag Tires...
Old 07-23-2007, 08:50 AM
blackout
blackout's Avatar
Default Ordering my DOT approved Drag Tires...
Debating between M/T ET Street Drag Radials 275/50/15..... and M/T ET Street Drag Slicks 26x11.5/15... they are both DOT but the car is going to be driven probably 15 miles a day...
I can't decide... help me out here... I know the Drag Slicks will hook a lot better at the track and can't decide!
-Jeff
blackout is offline
Old 07-23-2007, 08:51 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: Ordering my DOT approved Drag Tires...
drag radials.
FivePointOhh is offline
Old 07-23-2007, 09:49 AM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
Drag slicks are not DOT. THe ET Street Radial and the ET Street are DOT. I pull 1.5 60 foots on the radial, in the size your looking at, plus they are usually good for a couple mph on the big end. Unless your car has some serious HP and TQ the radials are the way to go.
JD1969 is offline
Old 07-23-2007, 01:14 PM
bighungrymatt
bighungrymatt's Avatar
I would get the radials imo
bighungrymatt is offline
Old 07-23-2007, 05:39 PM
ZachW04Stang
ZachW04Stang's Avatar
For daily driving go with the radials. I just swapped from radials to et streets for the track and I picked up 3mph with regular et streets and kept consistant 1.7-1.8 60fts. I could never seem to get the drag radials to hook even with suspension work.
ZachW04Stang is offline
Old 07-23-2007, 08:34 PM
JD1969
JD1969's Avatar
How can you not hook on a M/T dr? Esp with a 13 second car..My car pulls the front wheels about 5 inches with them.[&:]
JD1969 is offline
CS2007
06-25-2019 09:45 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Florida Regional Chapter
09-30-2015 08:04 PM
guitarman376
09-30-2015 05:54 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: Ordering my DOT approved Drag Tires...
