What Should I Do
RE: What Should I Do
thats a good mod to do when your bored, I would also suggest some weight removal. maybe a rear seat delete. Replacing it with carpet or make your own seat delete out of some thin wood. change your oil maybe?
OK, the first thing you need to do as a newb here is read our section rules and post in the correct sections!!
https://mustangforums.com/m_3236133/tm.htm
https://mustangforums.com/m_3560277/tm.htm
Tech questions/problems in the tech section only. If you're bored, post in the O/T section!!
