Shift Kit ?
Old 07-31-2007, 06:38 AM
90_Mustang_GT
90_Mustang_GT's Avatar
Default RE: Shift Kit ?
Looks like i misread if you were asking also, i took it a different way, i apologize to you 92civy...So a shift kit alone is different than a valve body? And where do you pick up that Transgo Shift Kit???
90_Mustang_GT is offline
Old 07-31-2007, 08:07 AM
samseed101
samseed101's Avatar
Yes, a shift kit is different. Typically, you install a shift kit into the stock valve body to get the desired effect. If you buy an aftermarket valve body, then chances are it will already be designed to give you the same desired effect.
Here's a link to where you can buy a TransGo shift kit for the AOD transmission.
samseed101 is offline
jwog666
12-27-2021 08:09 PM
Thunderball
15
11-22-2015 11:49 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Quick Reply: Shift Kit ?
