Subframe installation?
Old Aug 12, 2007 | 06:20 PM
fishermanjesse's Avatar
fishermanjesse
Default Subframe installation?
bought some subframes and there straight and whent i put the back one welded on it was like a 1/2-1inch away fron the subframe in the front and was against the floor pan what i do cut follr pan or just jack it up until its flush????????????????
Old Aug 12, 2007 | 06:34 PM
93hatch306's Avatar
93hatch306
Default RE: Subframe installation?
Had that problem with HPM connectors on my 93. Had the car on a lift, heated the subframe connector with an acetylene torch and bumped it up with a transmission jack. Weld with the tranny jack in place. Good luck.
Old Aug 13, 2007 | 02:39 PM
fishermanjesse
ttt
Old Aug 13, 2007 | 02:53 PM
TwotoneVert's Avatar
TwotoneVert
How are you test fitting them? The best method is to have the weight of the car sitting on the wheels. If you jack the car up and use stands or jacks to hold the car, it will not sit naturally as it does on the road.
Old Aug 13, 2007 | 04:17 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
if you have body sag you are supposed to jack it up by the sub frame to allow the weight of the car to straighten itself out. go on a flat surface, measure the distance between the ground and the front of your quarter panel, back of the fender to the groundand the middle of the door to the ground. if the are all the same or within the 1/4 inch body standards than you dont have sag and your connectors are off. if the middle of your door to the ground is lower than the other two measurements you have body sag.
Old Aug 13, 2007 | 09:13 PM
stang8689's Avatar
stang8689
always a fun job
Old Aug 13, 2007 | 09:52 PM
fishermanjesse
so will it hurt to jiust jack them up tight and flex the plastic floor pan covers
Old Aug 13, 2007 | 09:53 PM
fishermanjesse
body sag fixable?????????
Old Aug 13, 2007 | 10:17 PM
OnyxCobra's Avatar
OnyxCobra
Mine were curved when i held them up to the floor, what i had to do was put a jack under them to push it up enough to get the bolts through, then used the nuts to tighten it down against the frame.
And like mentioned make sure the car is sititng on it's tires, like on a drive on lift.
Old Aug 13, 2007 | 10:25 PM
fishermanjesse
so if the floor pan is pushed up a little it will be okay?
