fix the damn server this site is f'd up
#21
RE: fix the damn server this site is f'd up
ORIGINAL: FivePointOhh
i tried this for the heck of it at my work computer. every request timed out for the first 100 requests not one gets through. what does that mean? is it their security? this comp is really fast and i dont have trouble loading anything.
#22
ORIGINAL: 86GT 93LX
0 loss means its this server i would think????
Run the trace route to here again a few more times and look for any signs of packet loss along the way. Since you're only losing 2% or so, you may ahve to run it a few times before you see where it's happening. Then you can see exactly what server is causing the problems along the way.
Unfortunately, it's not always as simple as either being on your end or on the server end. That's ebcause there are a LOT of stops in between your PC and the server. And if any one goes down, then you have a problem. It's like a hold in a garden hose, or a vacuum leak. You get one hole along the way and it can ruin the results at the other end.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
