astroperformance
Old Aug 17, 2007 | 05:11 PM
dimebag's Avatar
dimebag
Default RE: astroperformance
yea see i would do that and all sept i hate the 2.95 1st gear... i like the 3.35... if my rebuild that i did doesnt work out... i think ill just buy from ddperformance
Old Aug 17, 2007 | 07:48 PM
PJB's Avatar
PJB
ORIGINAL: 86 5.0L
ok your bitching at astro becuase a STOCK, REBUILT T5 blew on you? pretty sure that would of happened on any STOCK T5
hell I've seen STOCK 5.0s break STOCK T5s
I broke the stock T5 in my stock S10 with a 125 hp 2.8 v6.
Theyre not that great of a tranny.
Old Aug 17, 2007 | 08:55 PM
dimebag's Avatar
dimebag
ORIGINAL: PJB
ORIGINAL: 86 5.0L
yea? did a gear blow or syncros take a ****?
Old Aug 17, 2007 | 09:28 PM
PJB's Avatar
PJB
I have no idea what I did to it. I took it apart but didnt have a clue as to what I was looking at. My guess is that something got bent.
It would get stuck between 3rd and 4th and Id have to unbolt the shifter and knock something around with a prybar to get it unstuck.
I drove it for 3 months without using 3rd until I found another tranny for it (I was too broke to get it fixed).
Im thinking the damage was caused by powershifting and using the truck like a one ton hauling stuff.
Old Aug 17, 2007 | 09:44 PM
ZachW04Stang's Avatar
ZachW04Stang
ORIGINAL: PJB
ORIGINAL: 86 5.0L
They are 2 different t5's. They are weaker in every aspect: case, input shaft, gears, etc.
Old Aug 18, 2007 | 11:26 AM
stang8689's Avatar
stang8689
I like the 2.95 with 3.73 rear. It doesn't fel any slower on take off but you get another 5mph out of first, plus 5th is .63 so i tach less on highway
Old Aug 18, 2007 | 12:35 PM
dimebag's Avatar
dimebag
ORIGINAL: stang8689
see what i dont like about that is where you pass thru the traps w. that set up.... if i got a trans w. a 2.95 id have to get 3.90s or something. buddy of mine had 3.73s and the 2.95 1st gear, and he had to shift to 4th right before the traps..... then again, if i were spraying, i would be higher up in 4th....
i dunno, hopefully itll be in tomorrow, but i think putting in the trans is getting put off untill next weekend now.... just a few more things to be certain about and make sure i did right.
Old Aug 18, 2007 | 05:45 PM
HACKGT350's Avatar
HACKGT350
still havent had a problem with mine at all. then again i bought the best one before a g-force t-5 that they had. i have ground 2nd gear a couple times...thanks to my gf grabbing my arm as im doing a burn out and just messing me up completely. other than that the trans has been perfect not a problem. once the break in was done i put the gm syncromesh in and it got even better.
wydopnthrtl
Jan 29, 2012 01:44 AM
Pony 5.0
Dec 19, 2007 04:17 PM
kweb288
Sep 26, 2007 02:24 PM
Scout2232
Jan 19, 2007 12:29 AM
CompOrangeHatch
Jan 11, 2007 12:26 PM
