Oil Pressure
08-22-2007, 09:54 PM
Oil Pressure
I have a 5.0 engine and was wondering what the oil pressure should be running at?
08-22-2007, 10:13 PM
RE: Oil Pressure
my engine has over 170,000 miles
cold idle: 52 psi
hot idle 44 psi
cold 2k rpm's: 60+ psi
hot 2k rpm's: 50+ psi
the rule of thumb is 10 psi for every 1k rpm's
use an aftermarket gauge to monitor oil pressure, the stock gauge is like a grandfather clock.
08-22-2007, 10:38 PM
RE: Oil Pressure
Ya i have an aftermarket gauge when i start it, it runs at about 50 then when it warms up a little over 40 so it seems to be close to what yours is
08-22-2007, 11:40 PM
RE: Oil Pressure
mine 175,xxx miles cold idle 55 psi warm idle about 25 thinking my main or rod bearings are getting a little wore out
08-23-2007, 07:18 AM
RE: Oil Pressure
With those miles i would say your oil pressure is great.
08-23-2007, 01:57 PM
RE: Oil Pressure
I have 'round oh 300,000 miles on mine and she runs 60psi@ cold idle, 30psi @ warm idle ; 60psi @ 2000rpm warm or cold... How 'bout them FORDS!!!!
08-23-2007, 04:37 PM
RE: Oil Pressure
mine idles at about 48psi, and under load about 68psi
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
wraith777
09-28-2015 10:49 AM
ccdguy
09-19-2015 05:20 PM
SteelerNation82
09-16-2015 07:11 AM
