Need an ac compressor
Old 09-05-2007, 01:43 PM
tmajikman
tmajikman's Avatar
Default Need an ac compressor
I just found out the clutch is taking a ****. I figured I would see if anybody had onelaying around. I figured it would be just as easy to get the complete unit instead of just the clutch. Let me know, thanks.... I am looking in the classifieds as well.
tmajikman is offline
Old 09-05-2007, 01:49 PM
93 LX FiveO
93 LX FiveO's Avatar
Default RE: Need an ac compressor
mine just crapped out today too. i took the clutch off
somehow it got tweaked, as if someone hit it with a hammer
i bought a delete kit and once its installed, u can have my old compressor. it is basicaly brand new but will need a clutch
93 LX FiveO is offline
Old 09-05-2007, 02:45 PM
tmajikman
tmajikman's Avatar
Thanks, I will let you know.
Old 09-05-2007, 03:17 PM
creekrat
creekrat's Avatar
I have one, but honestly you would be much further ahead to just put a new(or used)clutch on it. If you put the whole deal on then you would have to open your system up, thus loosing all refrigerant. To have the system evacuated and then refilled with new refrigerant would be fairly expensive and a waste of time and money, especially if it already works good.
creekrat is offline
Old 09-05-2007, 03:21 PM
tmajikman
tmajikman's Avatar
It actually leaks at every spring lock fitting and the low side r134 fitting that comes off the compressor, I have tried 4 fittings as well, I knew I would have to redue the orings and I figured I would do all of it at the same time. I do agree with you, If I had no leaks, I would just put a new clutch assemble on it.
Old 09-05-2007, 06:01 PM
tmajikman
tmajikman's Avatar
ORIGINAL: 93 LX FiveO
Let me know what you want for it, and let me know when you get your delete kit. Thanks alot
fastbackford351
10-01-2015 12:24 PM
fastbackford351
09-12-2015 09:42 AM
MXBT187
08-20-2015 02:36 AM
gagemcc
08-17-2015 10:30 AM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: Need an ac compressor
