Alternator
Old Sep 7, 2007 | 06:42 PM
shicaca's Avatar
shicaca
Default Alternator
I’m pretty sure my alternator is garbage, but I wanted to double check with you guys before I bought anything. My car will not start unless it is jumped. The car will than die after a few minutes. The three times it died I was at low rpm's (stopped at a light/stop sign). Ithas a new battery. Could this be anything other than an alternator? Will I need to buy another new battery even though it is new? How much do new alternators go for? Thanks for the help. I want my car on the road as fast as possible. It’s very depressing staring at it in the garage.
Old Sep 7, 2007 | 07:05 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
Default RE: Alternator
oem replacement alts are 70-80 bucks. you need the new wire harness for warrenty which is 10-15. and you want to replace it otherwise you car might catch on fire down the road later on.
i suggest since your alt is currently trash you upgrade to the 3G alt. you can pick up up fairly cheap and there is a very good write up in the tech section with pictures on how to do the swap, very simple.
yes your alt is junk btw
Old Sep 7, 2007 | 07:10 PM
nmerrill's Avatar
nmerrill
its trash, but if you wanna test it, the parts stores will do it for free.
Old Sep 7, 2007 | 07:26 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: FivePointOhh
Excellent advice, I concur this would be a great time to upgrade.
4cylinderplus2
Oct 9, 2020 07:45 PM
Golfsito
Oct 6, 2015 11:02 AM
MasterLanMan
Sep 26, 2015 10:03 AM
Wombatnation
Sep 13, 2015 09:16 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
