Why so slow?
man that sucks...i havean 87 ttop gt a stock junkyard block i have an f cam and an rpm2 upper stock maf and stock 19lbs, i have an off road h pipe and an 85 t5..on some 250 30 15 drag radials i ran 14 flat but slipped off the line and thru 2nd cause the tire were small....and 373 gears
Yeah, your 60' will have a huge impact on your et, but good grief, get you car tuned. It has to be WAY out. I'm running the same heads with a smaller cam a 3.00 gearwith a 4 speed and a 570cfm carb with a low rise dual plane and still manage low 13's at 106-107, and I know our vehicle weights aren't THAT dis-similar. Even when I pull 2.4-2.5 60's it still runs in the 13's. Your setupmust be leaving a LOT of power on the table without a tune, either that or something is wrong
ORIGINAL: 67mustang302
Theres only one tuner around here that does Mustangs but theyre supposedly horrible.
Driving with a bad tune isn't something you want to do, too lean and you could detonate or run too hot and burn valves, too rich and you'll wash oil from your cylinder walls and accelerate ring wear
ORIGINAL: PJB
How do I do that?
Im really unfamiliar with stall converters
ORIGINAL: Gary H
Try stalling it lower and letting the converter flash to a higher RPM.
http://www.competitionplus.com/03_25...confusion.html
It takes practice, you'll learn what works for the car with more seat time. A whole different world than street driving. Have fun though, now that you have the 1st time to the strip jitters gone you'll pay more attention to what you're doing.
