MAF to SD
It is posible....I have a SD ECU if you need it. I would be pretty easy really, lot better than going from SD to MAF. You will just have to repin the main harness and put in the SD ECU and remove your MAF, hook your BAP up to you manifold vacuum to make it a MAP and you are in business. Probably take you less than an hour.
i have always had better luck with my 88 GT and it was SD and i had a E 303 and stock injectors and never had a problem with it and it ran 13.0s 12.90s. and now i have a 342 and all trickflow boltons and i am running high 11s on pump gas and real low 11.0s with the shot on it so i am wondering if it will do anything eles when i do the switch and if not i can always switch it back.
jwog666
Dec 27, 2021 08:09 PM
stangin1996gt
Sep 21, 2015 11:01 AM
