Overheating
Old Oct 9, 2007 | 06:01 PM
HotpodStang's Avatar
HotpodStang
Default Overheating
So my water pump was leaking throuh the weap hole. I changed it and all seems fine and well with it but it is still overheating. Thermostat
Old Oct 9, 2007 | 06:24 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Overheating
You may have an air pocket and or the t-stat could be bad. W/ the car cold, open the rad cap. Start the car and let it idle. If the coolant is all the way at the top of the radiator, drain out some so there is about 3-4 inches of the radiator showing. This will give the system room to "burp" the air out. You'll prolly see a bunch of bubbling. As the car starts to reach operating temp, you should see coolant start to flow thru the radiator tubes and the level drop. Slowly add coolant to top off the system, button it up and take it for a spin.
BOB ROME
Jul 26, 2023 01:54 PM
mungodrums
Sep 29, 2015 09:18 PM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
