Roll cage Requirements
Old Nov 11, 2007 | 06:52 PM
hillbilly pony's Avatar
hillbilly pony
Default Roll cage Requirements
arethe requirements for roll cages different from track to track or is there a generic standard that everyone uses. While i have my car apart (see signature) should i put one in just to be safe. or do those who have similar set ups know whether i would need one at this point.
Would this suffice or is there something to be said for pure custom?
Jegster 940903K - Jegster 'Ford' Roll Cage Kits
[*]4 and 8 point roll bars manufactured from 1-3/4' x .134-wall mild steel tubing[*]10 and 12 point roll cages manufactured from 1-5/8' x .134-wall mild steel tubing[*]Includes 6' x 6' x 1/8' mounting plates[*]Some tube ends in some kits are notched while most tube ends are not notched for a better custom fit in your particular set-up. This 'extra material' provides you some leeway for a great fit and easier installation.[*]8, 10, and 12 point cages exceed NHRA and IHRA standards[*]Complete, easy-to-follow installation instructions included[*]Welding required
For a complete list of Jegster 'Ford' Roll Cage Kits, click here.
Ford Mustang, 1979-93 & Capri, 1980-86
550-940903K
8-Point Roll Bar Kit
$152.99
_uacct = "UA-204283-2";
urchinTracker();
Old Nov 11, 2007 | 07:24 PM
MadMan@TheWheel's Avatar
MadMan@TheWheel
Default RE: Roll cage Requirements
http://www.nhra.com/contacts/tech_faq.html
Read up
Old Nov 11, 2007 | 08:24 PM
hillbilly pony
So is it fair to assume that all tracks follow that guideline. even with the variety of governing bodies?
Old Nov 11, 2007 | 08:40 PM
MadMan@TheWheel
ORIGINAL: hillbilly pony
They have all for the most part standarized so far as safety requirements yes. IHRA has the same cage rules, it's something your never going to get around.
You are legal with a "roll bar" i.e. six point for a pretty good stretch. The problems I see people have is planning on E.T.'s above the needs of 8pt or better, then getting themselves into a situation where they need more cage. LEt me warn you ahead of time, most reputable cage builders will not add on to a stor bought cage. The MOST CRITICAL procedure for a cage is setting the main "hoop". Not to mention that the Diameter sizes will change with the point#'s. My advice to most folks is shop out a REPUTABLE cage and chassis shop in your area, and get a quote on your desired cage, theywill tell you if they know what they are doing what the best route to go is based on your plans for the car.
Just my opinion, but this stems from having a few cages installed and certified over the years. And having your cage Cert'ed is where the rubber meets the road. Basically once I had my last cage installed (10pt Chromoly on my last 93, there was a cert day arranged through my cage builder with about 5 cars needing certs) it was all pre-arranged and went smooth. I needed a cage that would allow sub-9 (to 8.50 with firewall intact). So I have been through it before.
flash_xx
Oct 16, 2015 07:23 AM
b8checker
Oct 8, 2015 12:55 PM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
