question for the drag racing ppl here
Old Nov 13, 2007 | 12:17 AM
  #21
telsonman's Avatar
telsonman
Default RE: question for the drag racing ppl here
well, i'd probably do it in the engine bay. It will be easier to keep it centralized there, and you won't have to worry about running all those wires. just a thought.
Old Nov 13, 2007 | 12:21 AM
  #22
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
relocate the battery to the trunk like I did and fab up a plate and put it there!!!!
Old Nov 13, 2007 | 12:24 AM
  #23
dimebag's Avatar
dimebag
yea relocating the batt wuld be tight, but if i can avoid doing that right now i will.... ill go out and look under the hood tomorrow... ill try to find a place for it
Old Nov 13, 2007 | 12:47 AM
  #24
67mustang302's Avatar
67mustang302
I say ignition also. And if whatever cam you git tries to give you fits with the factory SD, then you could go with Megasquirt like Adder
Old Nov 13, 2007 | 12:49 AM
  #25
dimebag's Avatar
dimebag
problem solved
http://static.summitracing.com/globa...s/sme-2802.pdf
Old Nov 13, 2007 | 01:04 PM
  #26
94StinkinLincoln's Avatar
94StinkinLincoln
i have the XE270 cam, the car really woke up at about 3k to 3500rpms and pulled hard to 6k.
i cant wait to get the motor fixed and put back together, the guy at the machine shop said maby high 11's for usre low 12's.
Old Nov 13, 2007 | 01:31 PM
  #27
67mustang302
347?
Old Nov 13, 2007 | 01:33 PM
  #28
dimebag's Avatar
dimebag
ORIGINAL: 94StinkinLincoln
good good thats what i like to hear.... other mods?
Old Nov 13, 2007 | 09:59 PM
  #29
ZachW04Stang's Avatar
ZachW04Stang
Your gonna need a rebuild kit for your rear end when you do gears. What about axles? 28 spline mosers will take you well into the 11's before being something to worry about. Cheap insurance since breaking an axle can me sending your car into the wall at the track.
The comp 270 is the same cam I had. It ran well with sd, just surged at idle a lot. Sometimes the car would idle and lope but most of the time it surged. Idling the car around 1000-1100 gets rid of the surge though.If someone ask you what wrong with your car just say "its broken, wanna race", it will shut them up.
Old Nov 13, 2007 | 10:07 PM
  #30
dimebag's Avatar
dimebag
hah good ****... i thought u had a differant cam, with a little less intake duration? eh, maybe i was mistaken
anyway, the rear is good to go... and if an axle breaks... well that would suck lol... but... i dont shock the rear hard enough i dont think[:@]
