Coil Spring Spacers
Old Nov 12, 2007 | 05:52 PM
85stang1373's Avatar
85stang1373
Default Coil Spring Spacers
Is there a such thing out there to raise my rearend to give it a more mean look? I also want them for some meatier tires.
thanks
Old Nov 13, 2007 | 10:12 AM
blwn93gt's Avatar
blwn93gt
Default RE: Coil Spring Spacers
get adjustable coil-overs. set the ride height where you want it.
http://www.maximummotorsports.com/
Old Nov 13, 2007 | 04:03 PM
Indy's Avatar
Indy
I used the Airlift 1000 air bags on mine, cause the adjustable coil-overs just were not in the budget. I like them cause it gives me about 2" up/down for height adjustment and I could adjust them independently to tune drag lauches! Eibach uses the airbags in one of there drag suspension kits, so they must be o.k. And... They were only 90 bucks and as easy to adjust as going to the local air pump at a gas station. Here a link...http://www.airliftcompany.com/al1000.html You can get them from Summit or even through Pepboys I think.
Indy
Old Nov 13, 2007 | 07:30 PM
capri debris's Avatar
capri debris
This is exactly what you're looking for... http://cgi.ebay.com/ebaymotors/80-81...QQcmdZViewItem, but the guy selling them is a complete A-hole!!! I bought a set from him and he is a real jerk... he won't rip you off or anything, but he is just a jerk. As much as I DON'T want to see him make another sale, I thought I should at least let you know the item you're looking for exists.
Old Nov 13, 2007 | 07:41 PM
92civy's Avatar
92civy
http://www.wolferacecraft.com/detail.aspx?ID=809
this is also great.
Old Nov 13, 2007 | 09:47 PM
ZachW04Stang's Avatar
ZachW04Stang
ORIGINAL: 92civy
this is also great.
^^^That requires cutting and welding, new control arms and a smaller diameter spring. Gets a little price going that way.
Old Nov 13, 2007 | 10:27 PM
ACE's Avatar
ACE
adj lower control arms from maximum motorsports FTW! and 4 cyl springs up front to lower a bit
firehorse02
Nov 16, 2015 11:28 AM
mungodrums
Sep 28, 2015 10:54 PM
Sixer4Life
Sep 28, 2015 07:05 AM
lmurf60
Sep 24, 2015 10:07 PM
